Seattle to consider ban on natural gas...
2»
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,880
  • RayWohlfarth
    I loved George Carlin @gennady
    Ray Wohlfarth
    Boiler Lessons
  • John Ruhnke
    John Ruhnke Member Posts: 1,020
    @RayWohlfarth
    Thankyou Ray for writing that great article. I like to think that maybe the message that I have been making in this thread is getting across to others. That is all we need. It is little steps that have a positive impact and make a difference. If we all work together we can influence the public. WE can get them to see the value in a good hydronics guy!!
    I am the walking Deadman
    Hydronics Designer
    Hydronics is the most comfortable and energy efficient HVAC system.
  • RayWohlfarth
    Thanks @John Ruhnke I appreciate it
    Ray Wohlfarth
    Boiler Lessons
    hot_rod Member Posts: 26,355
    I think Elko Nevada tried using uses their water mains as a loop field. The first year the connections were too close together and they froze the city water main, pulled too much heat out :). I heard they moved connections a block apart after that for more ground contact. I met an engineer familiar with that project a few years back
    Nevada has some district geothermal systems, Elko for one. Uses 176° ground water for heating applications.
    Some of the higher temperature geothermal wells provide electricity. Geo water flashes a low boiling point fluid to steam to spin the turbines, called binary systems.
  • John Ruhnke
    @hot_rod
    Awesome stuff!
    Hydronics Designer
    @hot_rod
    Awesome stuff!
    If ever you get to Reno head over to the Peppermill and ask for a tour of their geo system, they have been very open to taking plumbers on a short tour.
    They can pump over 1200 gpm of 170°F water from their main well. Handles all the DHW, pools, spas and heating load for the massive 1600 room resort.
    They fell a bit short on temperature with the last drill, they hoped to generate electricity also, if they hit 200F or more.
  • Leonard
    Leonard Member Posts: 903
    edited September 2019
    I'ld consider geothermal well, but I'm ~ 60 and I wonder if I would ever break even on cost. I run FHW 1.1 GPH heating oil, 50% duty cycle on -12 deg F night with some wind a few years ago (~lowest temp I've ever seen here in southern NH). The 61 year old furnace was sized to also heat never finished unfinished 2nd floor.
    Other issue is power failures........with a FHW oil furnace I don't need a very large generator to run it ~ < 1kw, could almost use a small battery bank and inverter...........With a heat pump I need a lot larger gen to handle the starting surge of the pump motor.....gen fuel$$$$$ and capital costs$$. Gens are THIRSTY 24/7 over a long outage, supplying 5kw uses ~three 55 drums of gasoline ( 168 gal) in a week, ~ $400. More gallons on propane ( ~ 20% more)
    Electric mandate ......Unless that electricity is made from non-fossil fuel energy sources the mandate is a joke.
    IF that extra electricity is made with fossil fuels then they will have just mandated a MINIMUM 150% increase in energy cost and CO2 output. Because at BEST power plants are only 40% efficient at converting fuel to power ( 1/40%)= 2.50 ......... And then there is the energy losses of transporting electricity over longer distances. I worked at GE on fuel cell R&D (~ 90% efficient) to replace turbines in the 80s.
    CO2 output is even worse if use a coal plant......And existing coal plants are the ones most likely to be used initially , till other plants are built to provide the extra power.
  • ChrisJ
    ChrisJ Member Posts: 17,036
    @Leonard my steam system uses around 12 Watts.
  • Leonard
    Likely why steam and vapor fuel was popular in the begining
