Determining what type of cast iron radiator
Fred Rappuhn
Member Posts: 107
I have a download chart from this site that determines the output of a cast iron rad. I am confused on what type of rad this is, (column or tube). And how many columns or tubes this is?
Thanks, see photo.
Thanks, see photo.
Me thinks column, setup for steam.0
It is a six tube0
> @Fred said:
> It is a six tube
Your'e right I got them confused.
Heres a chart i've used.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.expressradiant.ca/pdfs/product_classic_sizing_how_to.pdf&ved=2ahUKEwj87MDHvcfkAhVFvlkKHW3yC1oQFjAAegQIAxAB&usg=AOvVaw09Qqu1QvSPloP8xuZ6_-sF0 -
Looks like it’s a United States Radiator Co. radiator similar to the American Rad Corto type radiator.0
Thank you gentleman, I saved the chart, better to understand than the one I had.
I plan on converting this to run with hot water, output will be 5,760 BTU. The the size I will need for my application,
thank you
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
