Pex question, manifold suggestion and ideas
OhioRuss
Member Posts: 29
I’m installing a homerun system with cast iron rads. I have NIBCO oxygen barrier pex from Menards. Will I be okay with this or should I replace with PAP?
Secondly, any manifolds better for this than others? I plan on a Lochinvar boiler with Alpha 2 ecm and TRV’s on each radiator. I would like one with all the bells and whistle add-ons.
Finally, I have to run the s&r lines through the living space to get to the second floor. The walls are all solid brick and we don’t want chases. Is it best to just use black pipe or are their finishing sleeves or something else to run pex in? The ceilings are 10’.
Thanks for all the help
I’ve included a couple pics of the rads. We pressured washed the old paint off, rubbed the rust with an emery cloth and sprayed Rustolium hammered copper. We’re happy
pex-al-pex is better if only because of less linear expansion then OB pex.0
And nice looking rads.0
The cat is waiting for you to put a nice wide shelf a couple of inches above that radiator to increase its heat output and give her a nice warm place to sleep.
3PSI gauge0 -
We’re very pleased with the rads came out. We didn’t expect them to look so nice. I think the whole family will be fighting to radiator space this winter0
Caution, radiators can melt cats!Bob "hot rod" Rohr
Living the hydronic dream3
