scary water heater
Can't remember if I had posted this before, but here goes. This was in an old log home that I had to go in and winterize last winter. This thing was still operating making hot water! Notice the relief valve on the relief valve, the wiring, the washing machine hoses feeding it, and the earthquake strap. The rusty water around it is just a given.
Rick
Hi, Somehow, the lone shoe on top is fitting. That just might have won the ugliest water heater award!
Yours, Larry0 -
At least he used different colors for hot and cold.0
That one had my mouth hanging open for sure. Especially when I realized it was still working!
And I used to wear shoes like that when I was a kid!
Rick0 -
Looks like one of the hoses is new. Was that replaced as part of the winterization?
No it wasn’t. Must have been an upgrade. This was being used as a rental for awhile. Imagine the liability!
The new owners are ripping everything out, so this should be gone by now.
Rick0 -
Putting in hydronics?rick in Alaska said:The new owners are ripping everything out, so this should be gone by now.
RickAll Steamed Up, Inc.
Consulting0 -
Earthquake piping...
And the wire feeding it dosen't look like #10 which a water heater with a 4500watt element should have........ but why would the wiring be ok based on the rest...............0
That darn 80% rule........EBEBRATT-Ed said:And the wire feeding it dosen't look like #10 which a water heater with a 4500watt element should have........ but why would the wiring be ok based on the rest...............
Years ago I installed water heaters for home depot
. Thousands of water heaters. Was a lousy situation. Saw some similar to, but not quite this bad. OY! 0 -
Is that a boiler drain in place of the anode?0
Good eye! Forgot about that one. Also , the drain in the bottom is a regular hose Bibb, and the handle is jammed up against the tank, so it can not be opened. This one was definitely a classic.
Rick0 -
@rick in Alaska
Are the two wires sticking out from the top where the water heater is supposed to be wired, back fed and energized because of the upper t-stat direct wiring??1 -
Sorry, I am currently out of coverage area for the next few days and just saw this. Yes, they just bypassed the wires at top and went directly to the upper thermostat. I assume there must be a burnt wire, but never investigated it further.
Rick0 -
I assume they found that at the curb and wired it however they could0
Now that’s a serious DIY job
gwgillplumbingandheating.com
How does something like that go unnoticed by the gas co.? In the last 9 years I've owned my home Columbia gas has done a safety inspection on my meter and connected appliances twice and I had them out once after complaining about the gas regulator smelling.
Still have the meter in the basement that they refuse to move unless I pay them to move their own equipment... Maybe thats it, if my meter were outside they wouldn't ever see whats inside. Answered my own question maybe. But still. wow thats not homeowner DIY, thats a redneck hillbilly deluxe.0 -
gas co don't care,JakeCK said:How does something like that go unnoticed by the gas co.? In the last 9 years I've owned my home Columbia gas has done a safety inspection on my meter and connected appliances twice and I had them out once after complaining about the gas regulator smelling.
that thing is electric,
and scary
known to beat dead horses1 -
"Redneck engineering"! I think you just added that to the HeatingHelp lexicon.JakeCK said:...... thats a redneck hillbilly deluxe.
Consulting0 -
What has electric heater to do with gas company?JakeCK said:How does something like that go unnoticed by the gas co.? In the last 9 years I've owned my home Columbia gas has done a safety inspection on my meter and connected appliances twice and I had them out once after complaining about the gas regulator smelling.
Still have the meter in the basement that they refuse to move unless I pay them to move their own equipment... Maybe thats it, if my meter were outside they wouldn't ever see whats inside. Answered my own question maybe. But still. wow thats not homeowner DIY, thats a redneck hillbilly deluxe.Gennady Tsakh
Absolute Mechanical Co. Inc.2
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
