Why you should never dead-head a circulator
HeatingHelp
Administrator Posts: 718
I very much enjoyed the article well written and informative as always. But every time I read the word pump I had to chuckle.Cost is what you spend , value is what you get.
cell # 413-841-6726
This may be a stupid question, but in the formula for the 40 HP circulator, 20 BHP is used. How did 40 HP become 20 BHP? It looks like it has something to do with "(at shut off)". I don't know how to figure the difference.0
I think your spell check corrected your 'brake' to 'break', Dan....lol. As I recall my mech eng classes, it was called 'brake' horsepower b/c they applied a Prony brake to the end of the crankshaft on an engine to load up the engine and measure the output torque and then convert it to net output hp at the end of the shaft.0
A pony brake.Cost is what you spend , value is what you get.
cell # 413-841-6726
Actually, no, I believe it is "Prony" as in, Gaspard de Prony.......the guy that came up w/ the idea to apply a load to measure ouput torque. I believe it was the precursor to the dynamometer. When James Watt was coming up w/ the concept of "horsepower" he compared the lifting power of both horses and ponies, so maybe that's what you were thinking.Charlie from wmass said:A pony brake.
Since I am from Massachusetts I will use the excuse we don't have Rs up here. I can take the rest of the day off I have learned something new thank you.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1
