Why you should never dead-head a circulator
HeatingHelp
HeatingHelp Administrator Posts: 718
edited August 2019 in THE MAIN WALL
Read the full story here
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    I very much enjoyed the article well written and informative as always. But every time I read the word pump I had to chuckle.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • Nimrod66
    Nimrod66 Member Posts: 17
    This may be a stupid question, but in the formula for the 40 HP circulator, 20 BHP is used. How did 40 HP become 20 BHP? It looks like it has something to do with "(at shut off)". I don't know how to figure the difference.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    It’s Break Horse Power. We get that from the pump curve.
    Retired and loving it.
    Hammer
  • Hammer
    Hammer Member Posts: 14
    I think your spell check corrected your 'brake' to 'break', Dan....lol. As I recall my mech eng classes, it was called 'brake' horsepower b/c they applied a Prony brake to the end of the crankshaft on an engine to load up the engine and measure the output torque and then convert it to net output hp at the end of the shaft.
    A pony brake.
    cell # 413-841-6726
  • Nimrod66
    If I understand correctly, HP typically includes losses created before the point of use, for instance within a transmission or gearbox, whereas BHP is measured at the output shaft of the engine or motor.
    Hammer
  • Hammer
    That is exactly correct.
  • Hammer
    A pony brake.
    Actually, no, I believe it is "Prony" as in, Gaspard de Prony.......the guy that came up w/ the idea to apply a load to measure ouput torque. I believe it was the precursor to the dynamometer. When James Watt was coming up w/ the concept of "horsepower" he compared the lifting power of both horses and ponies, so maybe that's what you were thinking.
    Since I am from Massachusetts I will use the excuse we don't have Rs up here. I can take the rest of the day off I have learned something new thank you.
    cell # 413-841-6726
    Solid_Fuel_Man
