Boiler needs cleaning?
galileo
Member Posts: 13
I have a 600 thousand BTU boiler that was installed about 50 years ago. I flush it out on a weekly basis starting from the highest to the lowest flushing outlet. Last summer, I had my heating contractor install some parts and he mentioned that the boiler should be descaled from the outside since there was quite a buildup of soot etc just above the gas flues and at the back of the boiler. He suggested that he clean the external soot so I gave him the go.
That fall, during boiler start-up I noticed that the lowest flush cleanout was expelling steam with very little water instead of water only. After a few months that cleanout was exhausting steam only. This was quite unusual but at least the boiler was still working. I decided to have the boiler cleaned out at the end of the heating season which was this past spring. There are no steam boiler technicians anywhere near me and I attempted to find out if there is a way of descaling the boiler from the inside using some kind of descaling agent. The water in this area has a very high hard water rating.
Question: Not sure if I should attempt to descale the inside of the boiler with some type of solution? And, if so, what would be recommended?
If I don't solve this problem I may have no choice but to replace the boiler.
Any suggestions would be much appreciated.
Thanks
Thanks
@galileo , where are you located?All Steamed Up, Inc.
Consulting0 -
I'm in a small town, New Liskeard, in Northern Ontario Canada just below the 49th parallel. No one up here works on steam boilers anymore, unfortunately.0
I have contacted a chemical company in Toronto, Canada asking them if they have any suggestions on what kind of chemical treatments are available for my boiler. They have, as yet, not responded.0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
