Recommendations for thermostatic mixing valve.
nibs
nibs Member Posts: 516
DHW boiler output is 2.1gpm @140F. Prices are all over the map & this ole guy has no referents for mixing valves. Cost is very important to us, but do not want to buy a unit that might burn the grand little kids.
Watts seems to be middle of the road and a known brand, what output temp is best.
Once again the bugles play ............ WALL to the rescue.................. Thanks again for all the help.
    hot_rod Member Posts: 26,592
    Only one correct answer to that question :)
    The only angle pattern I know of. Accurate down to 1/2 gpm, The H port closes off so if you add a recirc, you will not get temperature creep.
    Settings are usually 120°F, or 110° for child care facilities and elderly housing. If you have smalls in your home the 110° setting might be considered.
    If you have a tankless or combi few feet of piping before the valve helps it keep a stable temperature, or a small tank DHW buffer, like some of the combis now include.
    Henry
  • HomerJSmith
    HomerJSmith Member Posts: 2,710
    Caleffi is such an innovative company!
  • JohnNY
    JohnNY Member Posts: 3,341
    I recommend the Caleffi 520 series of hot water controls as well.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
