T&P valve question
dennis73
dennis73 Member Posts: 2
edited July 2019 in Domestic Hot Water
Can i replace a T&P valve with a value of 150psi, 210 F max 105,000 BTU with a valve with value of 150psi, 210 F, 500,000 BTU
  • ScottSecor
    ScottSecor Member Posts: 1,034
    Yes. In your case as long as the inlet and outlet of the T&P valve are the same size of what is there now.
  • ScottSecor
    As in 3/4" inlet and 3/4" outlet.
  • dennis73
    yes
    hot_rod Member Posts: 27,457
    and the probe needs to be long enough to reach into the tank.
