T&P valve question
dennis73
Member Posts: 2
Can i replace a T&P valve with a value of 150psi, 210 F max 105,000 BTU with a valve with value of 150psi, 210 F, 500,000 BTU
Yes. In your case as long as the inlet and outlet of the T&P valve are the same size of what is there now.0
As in 3/4" inlet and 3/4" outlet.0
yes
and the probe needs to be long enough to reach into the tank.Bob "hot rod" Rohr
Living the hydronic dream0
- 123 Chimneys & Flues
