Radiant wall vs panel radiators
dave123
Member Posts: 67
For a new radiant installation done as part of a remodel, would more people prefer to install a radiant wall, or a panel radiator? I know most will say the radiant wall will create more comfort at a lower temperature than a panel radiator, but it also seems like quite a bit more work in the end, and runs the ongoing risk of nails/screws etc.
I lived with steam radiators for many years in the 1990s, and really liked them. They seemed fine to me as a heat source. I was thinking that hot water radiators would be about the same as they were, so I was wondering if there's enough of an improvement, in the opinion of those who've had them, to make the wall installations worth the extra work.
Appreciate any opinions.
I like the radiant wall, just keep the tubing above nail height.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Above nail height? I thought it was to stay below nail height.0
He means above where baseboard will be installed.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Hello, I put radiant tubes vertically in my walls and just put a dark plug top and bottom, in the wood trim so I'd know where not to pound nails. This may not work so well using a serpentine shape for the tubing.
Yours, Larry0 -
I appreciate the answers, but I'm still not sure if there's enough of a difference between panel rads and a radiant wall to make it worth the extra trouble. Can anyone speak to that?0
You can run lower temp. water through the radiant wall tubing than the panel rads for the same comfort and better efficiency. And you won't have the panel rads in the room as obstructions for a cleaner, more spacious feeling. Its probably easier to put a couple panel rads in (labor-wise) than the equivalent amount of radiant tubing. If it was a "finished" remodel--def. panel rads. For a "new" remodel, I'd do radiant walls.0
It depends on how much you need to do to the wall to install the radiant and finish it.
Typically a layer of insulation board over the wall, transfer plates and tube, fur strips, re-sheetrock. Or use a wood finish over the radiant.
The panel rads involve mounting brackets and running pex to the locations.
Is it work would be doing yourself? To hire it out, certainly the radiant walls involve more trades and $$.
If you like the looks of the panel radiators, that would be quicker and less $$.
They can powder coat panel rads too any color of finish you chose, also. At the EEE show, QHT inc.had some nice looking red ones on display.Bob "hot rod" Rohr
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
