Dahl Pex Balancing Valve Adjustment
KeenGreen
KeenGreen Member Posts: 27
Hello Wall.
Does anyone know of a chart or rule of thumb for adjusting a Dahl Pex Balancing Valves?
Something about turning it off then opening slowly so many turns to get a certain flow rate?
Sorry if this sounds vague, but I couldn't find anything on the WWW.
Jeff Green
  • JeffM
    JeffM Member Posts: 185
    https://www.amresupply.com/file/133952/
    Is this what you're looking for? It's just % of full flow per turn, doesn't give you a GPM since that will depend on circulators, etc.
    - Jeff
  • KeenGreen
    @JeffM That is exactly what I was looking for. Thank you for sending it over. I now have a copy in my files.
    Thanks again.
    Jeff G
