Spark cable
Brian B
Member Posts: 4
Hi, I have a Teledyne Laars D-JVS-125-C boiler. The original control box had to be replaced during the dead of winter. The original part replacement wasn’t available so they had to use a Honeywell that was a different size. Long story short, it has stretched the spark cable so short that cover cannot fit back on. Where can I get a new Spark cable? Would spark plugs wire work? Please advise, thanks!
HONEYWELL 394800-30 0" Ignition Cable Assembly with right angle boot
by Honeywell
4.7 out of 5 stars 2 customer reviews
Price: $43.94 & FREE Shipping
Get $50 off instantly: Pay $0.00 $43.94 upon approval for the Amazon Rewards Visa Card. No annual fee.
Factory Authorized Honeywell Distributor
Honeywell
Honeywell
› See more product details
New (4) from $43.94 & FREE shipping.
Found on Amazon. Do not use automobile cable!2 -
Thank you.0
Gas Ignition Module Accessories
Material Number Description Used With
392125-1/U 25 in. ignition cable assembly with a right angle boot on the igniter end and a straight boot on the module end. For use with the S86/S87 family.
S86/S87 family
392125-2/U 36 in. ignition cable assembly with a right angle boot on the igniter end and a straight boot on the module end. For use with the S86/S87 family.
S86/S87 family
394800-30/U 30 in. Ignition Cable Assembly with a right angle boot for ignition terminal and 1/4 in. straight quick connect at module end for S8600 family.
S8600 family
394800-32/U 32 in. Ignition Cable Assembly with a right angle boot for ignition terminal and 1/4 in. straight quick connect at module end for S8600 family.
S8600 family
394800-36/U 36 in. Ignition Cable Assembly with a right angle boot for ignition terminal and 1/4 in. straight quick connect at module end for S8600 family.
S8600 family
394801-30/U 30 in. ignition cable assembly with a straight boot on igniter end and a 1/4 in.straight connect at ignition module end.
S8600 family
394801-36/U 36 in. ignition cable assembly with a straight boot on igniter end and a 1/4 in.straight connect at ignition module end.
S8600 family
4074EPM/U Quick connect to Rajah adapter for S8600 family S8600 family1 -
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
