Spark cable
Brian B
Brian B Member Posts: 4
Hi, I have a Teledyne Laars D-JVS-125-C boiler. The original control box had to be replaced during the dead of winter. The original part replacement wasn’t available so they had to use a Honeywell that was a different size. Long story short, it has stretched the spark cable so short that cover cannot fit back on. Where can I get a new Spark cable? Would spark plugs wire work? Please advise, thanks!
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    HONEYWELL 394800-30 0" Ignition Cable Assembly with right angle boot
    by Honeywell
    4.7 out of 5 stars 2 customer reviews
    Price: $43.94 & FREE Shipping
    Get $50 off instantly: Pay $0.00 $43.94 upon approval for the Amazon Rewards Visa Card. No annual fee.
    Factory Authorized Honeywell Distributor
    Honeywell
    Honeywell
    › See more product details
    New (4) from $43.94 & FREE shipping.
    Found on Amazon. Do not use automobile cable!
    Intplm.Brian B
  • Brian B
    Thank you.
  • Do they have an angle connector for the spade connection? I end up bending the end to get the cover on.
    Brian B
  • Tim McElwain
    There are all kinds of adapters available. Go to Honeywell Catalog and look for accessories usually six digit numbers.
    Brian B
  • Tim McElwain
    Gas Ignition Module Accessories
    Material Number Description Used With
    392125-1/U 25 in. ignition cable assembly with a right angle boot on the igniter end and a straight boot on the module end. For use with the S86/S87 family.
    S86/S87 family
    392125-2/U 36 in. ignition cable assembly with a right angle boot on the igniter end and a straight boot on the module end. For use with the S86/S87 family.
    S86/S87 family
    394800-30/U 30 in. Ignition Cable Assembly with a right angle boot for ignition terminal and 1/4 in. straight quick connect at module end for S8600 family.
    S8600 family
    394800-32/U 32 in. Ignition Cable Assembly with a right angle boot for ignition terminal and 1/4 in. straight quick connect at module end for S8600 family.
    S8600 family
    394800-36/U 36 in. Ignition Cable Assembly with a right angle boot for ignition terminal and 1/4 in. straight quick connect at module end for S8600 family.
    S8600 family
    394801-30/U 30 in. ignition cable assembly with a straight boot on igniter end and a 1/4 in.straight connect at ignition module end.
    S8600 family
    394801-36/U 36 in. ignition cable assembly with a straight boot on igniter end and a 1/4 in.straight connect at ignition module end.
    S8600 family
    4074EPM/U Quick connect to Rajah adapter for S8600 family S8600 family
    Alan (California Radiant) Forbes Member Posts: 4,643
    edited June 2019
    Perfect ! Thanks, Tim!
    394800-36DU angle spade, angle boot
    394801-36DU angle spade, straight boot
    I tried Grainger, Johnstone Supply and Supplyhouse. None of them carry these. Any idea who does?
    Brian B
