Newest Rinnai Install
Just finished it this week.
Not as pretty as some of yours.
Ironman
  • JUGHNE
    JUGHNE Member Posts: 11,547
    Pretty good looking to me.
    I see the pump inside the unit and one at the manifold.
    But what is the story with the pump flanges bolted together on the lower right?
  • nibs
    nibs Member Posts: 516
    Looks good, your solder joins are much better than mine, these ole hands are kinda shaky so my joins embarassingly look like they were done with a butter knife.
  • Ironman
    Ironman Member Posts: 7,900
    Looks good to me.
    Bob Boan
    Alan (California Radiant) Forbes Member Posts: 4,697
    edited May 2019
    Good eye. I'd forgotten that the boiler already comes with a pump and had installed a 15-58 there.
    One thing I'm starting to do is to put hose bibbs at the x-tank to make it easier to drain and check tank pressure. The last one I checked that didn't have a drain took 30 minutes to slowly drop the pressure because I didn't want the water to go everywhere. Doesn't Webstone have something for this?
    JUGHNE
  • Keith M
    Keith M Member Posts: 78
    Pressure relief valves should be installed vertically. Technically the pressure relief valve should be above the heat exchanger but I believe only one state adheres to this part of the code. I also recommend the relief valve's discharge pipe ends around 6 inches from the floor with the end made that is cannot easily be capped or plugged.
    Nice work.
  • bob eck
    bob eck Member Posts: 930
    What model Rinnai is this unit?
    I see Rinnai just came out with a i series combi boiler that will do heating and domestic hot water at the same time.
    The two smaller models deliver 4.1 GPM domestic hot water
    The larger model delivers 5.1 GPM domestic hot water
    All three at a 70 F temp rise.
    Looks like a interesting combi boiler.
  • wesPA
    wesPA Member Posts: 41
    Looks good. Webstone does makes an expansion tank isolation valve that works really nice in most cases. Reasoably priced as well
  • Thanks for all your comments. I value them!
    Bob: This is an e50c and I believe the i series will take the place of the e series.
    wes: Beautiful work. Thanks for the Webstone lead.
    Keith: The relief lines in the photo terminate outside the shed and daylight about 6" above grade. Code is 6" - 24" above grade and I don't believe we have those other restrictions on relief valve placement out here. You would have to disfigure the copper at the termination to prevent it from being capped, no? Good to know what others do in other parts of the country.
