Gravity Coil Manufacturer Recs
BigRob
Member Posts: 332
Can anybody share some other manufacturer options like the following:
https://lrccoil.com/wp-content/uploads/2018/10/Copy-of-GC_150203_65.pdf
Looking for alternatives to compare - I need them to have a condensate drain because it's an overhead application. The heat load is 1800 btu/hr
Thanks!
Thanks!
I am sure the coil you named has a drain connection. They mention a drain pan.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
