Gravity Coil Manufacturer Recs
BigRob
BigRob Member Posts: 332
edited May 2019 in THE MAIN WALL
Can anybody share some other manufacturer options like the following:
https://lrccoil.com/wp-content/uploads/2018/10/Copy-of-GC_150203_65.pdf
Looking for alternatives to compare - I need them to have a condensate drain because it's an overhead application. The heat load is 1800 btu/hr
Thanks!
    EBEBRATT-Ed Member Posts: 19,427
    I am sure the coil you named has a drain connection. They mention a drain pan.
  • BigRob
    Yes, thx, also just looking for alternatives.
