Oxygen Reading
I'm just curious. What's everyone's oxygen reading when you start up your combustion analyzer? Ours is 20.9%.
  • STEVEusaPA
    Me 2, on both a Bacharach Insight Plus, and a UEI 155.
    When I'm done taking a reading I usually let it run until i have 20.9% 02 & 0 ppm CO before shutting it down.
  • So do I. I'm told it clears the CO sensor and makes it last longer.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,569
    20.9 is the number
    Steve MinnichSolid_Fuel_ManAlan (California Radiant) Forbes
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    If the probe isn’t in flue pipe, that’s what you’re going to get.
    Steve Minnich
  • Amazing how smart you can be and still know nothing.
    Solid_Fuel_Man
  • Zman
    Zman Member Posts: 7,611
    Welcome to my world. The percentage of oxygen in the air is the same at high altitude. There is however much less air.
    Analyzers read 20.9 at 11,000' just like sea level.
    Albert Einstein
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,825
    Hello, Isn't the problem in the article just that they didn't explain their metrics? At sea level you get 100% of that 20.9%. On top of Everest, you get only 33% of that same 20.9%. Otherwise at sea level, with their 100%, it would be way to easy to literally set the world on fire :o Methinks that article needed a better editor. o:)
    Yours, Larry
    Alan (California Radiant) ForbesZmanSolid_Fuel_Man
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    It's pretty amazing how our analyzers are all reading the same percentage. Well calibrated (to the atmosphere). The pie chart also explains why compressed Nitrogen is the cheapest gas, and the comparatively high cost of CO2.
    I always learn something here at HH! You guys are the best.
  • HomerJSmith
    HomerJSmith Member Posts: 2,640
    That is a good check, if it read anything else maybe you need a calibration. Know your tools!
    Solid_Fuel_Man
  • Zman
    I tried to stick my old EUI in an oxygen rich environment and it would not read higher than 20.9. I think it was programmed that way. Have not tried the Testo 320.
    Albert Einstein
  • Steve Minnich
    My Testo 320 reads 20.9 as long as the sensor is good.
    Steve Minnich
