Radiant Panel baseboard
Member Posts: 4,640
As far as I know, this company no longer exists. Does anyone know of surplus material still around?
Nice - thanks!
I'll give them a call and remain optimistic.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
You're most welcome, Alan. After you've done whatever needs doing to that system, I'd be most interested in hearing how it performs and what you think of it in our somewhat benign California climate.0
It's an interesting building. An Oakland Firestorm house, built by an architect for himself. Large open spaces with large windows to enjoy the view and give up heat.
There are two Lochinvar RBN 090 boilers. One for the Radiant Panel baseboard and one for the concrete embedded radiant. Non-barrier tubing throughout ala Warm Floors.
They are thinking of replacing the boiler(s). What would you use for non-barrier tubing?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
@Alan (California Radiant) Forbes
The RadiantPanel is still being made, not by RTI any longer, now by Hydronic Alternatives
http://www.hydronicalternatives.com/products/radiant-panel-baseboard-and-accessories
Dave H
Dave Holdorf
Taco, Inc
Nice - thanks!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
