Honeywell L408J 1009 Vaporstat Failures
I suspect that the diaphragm is not not being sealed around the edges properly and that is allowing pressure to leak away, drawing in non-compressible water into the diaphragm space.All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
how does it matter that water (or oil, or air) is under the diaphram, it still pushes up, right?
isn't this just like a pressure reducer diaphram doing its same thing?
or is this that the sensitivity of ounces isn't transmitted well thru the water?
without a gage there telling us otherwise I'm guessing we're just leaking and not building pressure at the trol.known to beat dead horses0 -
I just installed a new Honeywell L408J1017, 0-4psi vaporstat today and it makes that popping sound. The last 2 did not make that noise. Should I exchange it or wait and see?0
- 116 Geothermal
- 15.8K Strictly Steam
