Baxi Luna 310 FI - no power to pump
trogdor2882
Member Posts: 3
Hi - I have intermittent power going to the pump on my Baxi unit. I think it might be relays on the control board. Is it possible to replace these myself? (My local service guy thinks its not possible and needs the entire board replaced and he wants 800 bucks for parts and labor)
I had heard that Baxi no longer supports their older models, i.e. no circuit boards available, but I may be wrong (see moniker below).
I suppose that if you're good with a soldering gun and can find and replace the bad relay, you can save a lot of money. I just replaced the capacitors on my TV and didn't have to buy a new one.
Call tech. support at (800)461-4657
Baxi's don't seem to be very popular amongst us here on The Wall. I've worked on a few of them and have been very frustrated. Other than replacing the DHW diaphragms, I stopped servicing them.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
that is correct - I believe it was just this year they made the control board end of life. I'll give the relays a try first since when I tap them, I lose hot water.0
Let us know how it goes.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Changed one of the relays and got hot water working again! $2.80 for the relay, $20 shipping.0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
