Visual illustration of paying oil company to vent your mains
vvzz2
vvzz2 Member Posts: 17
My Gorton no2s(and some no1s) are here. But before I put them on, I wanted to collect some data. And what better tool to se inside the pipes than a thermal camera. Here’s a short video I took - you can almost feel that steam struggling hard to push all that air via the radiator vents
https://youtu.be/taRBoh5Ql-U
STEVEusaPA
  • Big Ed_4
    Big Ed_4 Member Posts: 3,348
    While your at it........ insulate your mains
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Excellent and informative video, which should be seen by anyone with bad main vents!—NBC
  • vvzz2
    And here’s one trunk main after adding 3 gorton #2s. Huge difference in my opinion. And I haven’t installed the vaporstat or lowered the pressure yet.
    https://youtu.be/n5By2ALWsbc
    I will continue reporting as I take further steps. I hope this information is useful
    Steamhead Member Posts: 18,184
    Impressive! Did you time how long it took for the main to heat to the end, before and after?
    Consulting
  • vvzz2
    Not for that main. I was too eager to install the vents. I have 4 more mains to go, so I’ll time them.
