Visual illustration of paying oil company to vent your mains
vvzz2
Member Posts: 17
My Gorton no2s(and some no1s) are here. But before I put them on, I wanted to collect some data. And what better tool to se inside the pipes than a thermal camera. Here’s a short video I took - you can almost feel that steam struggling hard to push all that air via the radiator vents
https://youtu.be/taRBoh5Ql-U
1
While your at it........ insulate your mains
Excellent and informative video, which should be seen by anyone with bad main vents!—NBC0
And here’s one trunk main after adding 3 gorton #2s. Huge difference in my opinion. And I haven’t installed the vaporstat or lowered the pressure yet.
https://youtu.be/n5By2ALWsbc
I will continue reporting as I take further steps. I hope this information is useful0 -
Impressive! Did you time how long it took for the main to heat to the end, before and after?All Steamed Up, Inc.
Consulting0 -
Not for that main. I was too eager to install the vents. I have 4 more mains to go, so I’ll time them.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
