Circuit Solver
Zman
Member Posts: 7,611
in Oil Heating
Has anyone had experience with this product?
It would be used in a condo building DHW recirc system paired with a delta p circulator.
http://www.circuitsolver.com/wp-content/uploads/2019/02/CSU-CSUA-CSUAS-Sell-Sheet.pdf
Albert Einstein
Albert Einstein
here is another, adjustable, legionella protective version.
https://www.caleffi.com/usa/en-us/catalogue/thermosettertm-thermal-balancing-valve-116140aBob "hot rod" Rohr
I like the thermosetter solution since it will only allow just enough to flow to meet the temperature setpoint.0
