Proper Steam Vent Location?
New England SteamWorks
Member Posts: 1,528
newenglandsteamworks.com
4
WHAT THE ! ? LOL0
And do I see some red firestop caulk there too?0
Only seeing the single copper riser.....how well does the system work? (that had to be a HO vent install?)0
As you would imagine, -doesn't work well at all....New England SteamWorks
newenglandsteamworks.com0 -
Just stuck and old vent into the combustion test hole0
No Way!0
Just when you think you've seen it all......................All Steamed Up, Inc.
Consulting0 -
Maybe it's an April fools joke. A day late???0
Hope he put dope and Teflon tape on it0
I suspect as stated above, it's just to plug the test hole. I hope it's stuck closed.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
