remote heat pump water heater
Wayco Wayne_2
Member Posts: 2,479
We are considering a heat pump water heater for a high efficiency demonstration SEED building. The problem is, it will be in a small mechanical closet in a super insulated enclosure. I won't have any air circulation and don't think I will have enough heat to transfer to the water. There has to be a product out there that has a remote unit so I can pump heat in from the outside through refrigeration pipes. Is anyone aware of such a product?
- 50 Industry Classes
