Steam Air Vent Pushes Air All at Once
njwags95
Member Posts: 15
Steam 4 foot baseboard on 2nd floor bedroom air vent releases all air at once, not gradually, making a loud whooshing sound. This seems to happen in the early morning when the system is heating from 65 to 68. Air vent is a Varivalve. Any ideas? Thank you.
That's not what's happening. And baseboard and steam, assuming it's a 1-pipe system, is a bad combination that'll never work well anyway.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Yes, one pipe system. Half the house has baseboards, some longer. This one is the only that behaves this way.0
What happens when you adjust the valve?0
Post a picture of that "baseboard" Let's see what you are calling a baseboard and where the vent is. Varivalves are probably the worst vent you can put on a steam system. They vent too fast for a radiator.0
Sounds to me that the main air vent may not be working or undersized. Had the same thing on my one pipe system at my house
Ray Wohlfarth
Boiler Lessons0 -
This is the baseboard with the Varivalve to the right. I currently have it 1/3 open since it was mentioned it releases air too quickly. Thanks.0
