1981 WM CGM-7 Gas Boiler Install/Service, Ignition & Essex Gas Control pdfs Now On Heating Help.
D107
Member Posts: 1,944
Scroll down lower in the thread for the urls.
Yes see below as a link on this site.0
We'll archive it. Feel free to send the scan along. Thanks!D107 said:Yes i might as well just scan it in and send pdf to Erin. I've seen parts of the manual online but i have it complete. I had thought of this but then thought it's not old enough to be worth archiving. But i can scan it real quick.
President
HeatingHelp.com0 -
Sent install/service manuals and Essex Gas control and Ignition as well.0
You can now find them here: https://heatinghelp.com/heating-museum/weil-mclain-p-cg-and-cgm-gas-fired-boilers-series-7-circa-1981/
And here: https://heatinghelp.com/heating-museum/weil-mclain-cgm-7-ignition-essex-gas-control/
Thanks, @D107!President
HeatingHelp.com2 -
Thank you both for that.
However, I have a few Essex 243/244 gas valves. 1" &1 1/4"
These have a separate pilot sol control valve.
Tim McElwain helped me with these in Nov of 2018.
He has truck load of info on everything and was going to inquire about putting some of it here, but as he said, where does one start?0 -
My daughters asked me that when they were little and it was time to clean up their rooms.
I'd point at a doll on the floor and say - start with that. And then, go on to the next one.
Steve Minnich0
