System 2000 Fuel Filter Cross-Reference
All of the plumbing supply houses and fuel oil dealers were closed, and none of the home center stores near me stocked them. And there's no way I was going to spend $150 or more on a service call for a new filter.
I started searching with Google, but kept coming up empty. I found an old post on this site, but the one filter mentioned wasn't available.
So I started searching using the specs of the filter and found a suitable replacement that is intended for Cummins diesels, and is available in many auto parts stores.
The list, starting with the OEM filter:
Energy Kinetics 10-0933
Napa 3109
Wix 33109
Fram P3528A
Hastings FF945
Baldwin BF957
Donaldson P550105
Fleetguard FF105
Luber-Finer LFF5
Carquest 86109
How did you determine you “desperately” needed a filter?
Even though the spin on is standard the EK requires some special knowledge and you shouldn’t be working on it without the proper tools and skill.
Put the old one back on. Hopefully you can properly bleed it and it will work until tomorrow.There was an error rendering this rich post.
Been there done what? You’re also a homeowner who took a filter cartridge off your own system and didn’t have a spare?
My guess is the burner wasn’t running. HO started taking things apart, damaged the filter. Oops. If there was no flow and the filter actually completely plugged, that filter was in there way too long, and there are probably other things that need attention.
Should’ve called someone first instead of trying to save some money.There was an error rendering this rich post.
2 -
The Garber R is the correct filter. The list of filters you found for the Automotive industry do not specify the Epoxy coating. The long term protection from corrosion may be an issue and the filter could leak. I would recommend changing the automotive type to the residential type filter. We are now using the Garber Filter as a standard option for the Smart Filter.
"Mitch"
Energy Kinetics"Mitch"
Roger Mitchell
Senior Technical Representative
Energy Kinetics2 -
Uuh. You're quoting the wrong post in the wrong context. I was only trying to suggest that the op have extras on hand. And that we all make mistakes. Coming to this sight will hopefully help so those who make those mistakes will not make them again.STEVEusaPA said:Been there done what? You’re also a homeowner who took a filter cartridge off your own system and didn’t have a spare?
Should’ve called someone first instead of trying to save some money.0 -
Your sage advice is to have one on hand before you remove the old one? And most people don't know this?
The OP wanted to save money by trying to do something he had no knowledge or experience. That's his right and his prerogative.
I responded to him the same way I would if someone called my company with the same issue. Actually I responded nicer.
Trying to help I asked "...How did you determine you “desperately” needed a filter?..."
That's the crux of the issue anyway. If he has a clogged oil line, a new filter is worthless, right?
It's probably moot anyway as the OP didn't come back.
You must be incredibly fit, what with all the jumping to conclusions that you do.STEVEusaPA said:How did you determine you “desperately” needed a filter?
I needed a filter because mine was clogged, starving the pump and burner, preventing the furnace from running.0 -
Home Depot by me only had the filter packaged together with the filter housing for $35HVACNUT said:Big box stores dont carry spin ons?
If it was clogged a month ago, it must be really clogged now. What's the vacuum reading?
I don't remember the reading, but the vacuum gauge was at the red line.
I changed the filter that day because I found the Carquest 86109 diesel fuel filter at the auto parts store.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
