What is this?
mrgreen127386
Member Posts: 2
in Oil Heating
I need to repair leaks in the copper fittings on this system. Should I remove this? Why did they plumb it like this?
They've connected the supply and return. It must be making the circ pump work much harder than it should.0
Maybe an attempt at primary-secondary pumping?All Steamed Up, Inc.
Consulting1 -
That looks like somebody made a mistake? Or, they forgot to install a valve between the branches of the two tees?0
Is that off a boiler system and are their multiple circulators on this system?
I suspect 1 circulator at the boiler and 1 downstream of those tees.
Is this a Weil Mclain Ultra??
If so you probably need to leave those tees although I am not crazy about that set up0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
