What is this?
mrgreen127386
mrgreen127386 Member Posts: 2
I need to repair leaks in the copper fittings on this system. Should I remove this? Why did they plumb it like this?
  • mrgreen127386
    They've connected the supply and return. It must be making the circ pump work much harder than it should.
    Steamhead Member Posts: 18,714
    Maybe an attempt at primary-secondary pumping?
    Consulting
    SuperTech
  • Intplm.
    Intplm. Member Posts: 3,083
    That looks like somebody made a mistake? Or, they forgot to install a valve between the branches of the two tees?
    EBEBRATT-Ed Member Posts: 20,482
    Is that off a boiler system and are their multiple circulators on this system?
    I suspect 1 circulator at the boiler and 1 downstream of those tees.
    Is this a Weil Mclain Ultra??
    If so you probably need to leave those tees although I am not crazy about that set up
