Top of Tank fuel line install-help/verify
Bob518_802
Member Posts: 5
My bottom of tank valve is broken, can I pull from top of tank with one line, vs two lines as I have seen in the past?
Admittedly I broke the bottom valve either when trying to get built up ice from under tank or when I over tightened or stripped it yesterday as I was trying to figure out why I wasn’t getting any fuel.
My tank isn’t a permanent install, we fill it ourselves. The closest permanent installation will need a TigerLoop, as it is at least a hundred feet away, and down grade... and due to changing regulations needs to be jacked up and have a slab installed, unless I just pour cement around legs... (but this is not something that I am looking to do before spring) in addition to the TigerLoop I was thinking of having a way to fill the line manually from the high point down to the tank to make priming easier?)0
The tank needs a proper slab. Pouring concrete around the legs is not to code.
Why not just replace the valve and keep the gravity feed?There was an error rendering this rich post.
You can pull from the top of the tank with 1 pipe or 2 pipe depends on how much lift you have. The suction & return line if used must be absolutely tight. You get the lines tight you don't need a priming tee.
Keep the line (both of them) 3" off the bottom.
Or use vacuum cleaner (soot master) to pull a vacuum on the oil tank and change the valve at the bottom. You probably need a professional for this.
Two pipe is always better...right @STEVEusaPA LOL
Of course, if you remove the bypass plug, plug the return port on the pump, and cap off the return lineEBEBRATT-Ed said:...
Ed, I hope we get to bump into each other one day...either at Hershey this Spring or NYC steam palooza in August
Thanks for the information, we have been filling our own fuel oil/off road diesel for about three-four years, I started with a 55 gallon drum that I got from someone with an old junk monitor heater, then I upgraded to a 265 fuel oil tank, nothing up to code. And both on deck of old restaurant buildings second floor (old restaurant is almost like a split level ranch. The front of the building is level with the street. And the back deck is close to the level with second floor. So the current tank is gravity fed and only about 10 feet front the fuel tank to the furnace.
The permanent tank near the front of the building will be properly upgraded this coming spring/summer... after this recent experience... (remembering that experience isn’t always when you get what you wanted!)
The plus side will be that I will look back on this, and I will have learned quite a bit, which will come in handy in the future as I work to make things better at camp.0
- 50 Industry Classes
