Header fail
Mike_Sheppard
Member Posts: 696
Only used one outlet. Reduced size of outlet. Header piped wrong. Been here for a long time though.
Has also been leaking for over a year now.
Never stop learning.
1
It never ceases to amaze me how forgiving steam heat is to truly … unusual... arrangements. One reason why it is so hard to convince people -- including pros -- to do it right.Br. Jamie, osb
What size LGB is that? I think they all have 6" steam tappings but you can reduce them on the smallest sizes.
And of course they were too cheap to remove the old oil tanks.....All Steamed Up, Inc.
Consulting0 -
Seen worse. Has a header probably too small, has a way for water to get out of the header and 2 take-offs.
Not right but may work0 -
@EBEBRATT-Ed It hammers. Leak at water line. Mid cycle there was hellacious hammer in the wet returns. Hope I get a chance to comb over the system.Never stop learning.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
