Header fail
Mike_Sheppard
Mike_Sheppard Member Posts: 696
edited February 2019 in Strictly Steam
Only used one outlet. Reduced size of outlet. Header piped wrong. Been here for a long time though.
Has also been leaking for over a year now.
Never stop learning.
Jellis
    Jamie Hall Member Posts: 26,162
    It never ceases to amaze me how forgiving steam heat is to truly … unusual... arrangements. One reason why it is so hard to convince people -- including pros -- to do it right.
    Steamhead Member Posts: 17,886
    What size LGB is that? I think they all have 6" steam tappings but you can reduce them on the smallest sizes.
    And of course they were too cheap to remove the old oil tanks.....
    Consulting
  • Mike_Sheppard
    @Steamhead LGB7
    You’re right. One tapping at 4 inch. It’s correct.
    EBEBRATT-Ed Member Posts: 18,208
    Seen worse. Has a header probably too small, has a way for water to get out of the header and 2 take-offs.
    Not right but may work
  • Mike_Sheppard
    @EBEBRATT-Ed It hammers. Leak at water line. Mid cycle there was hellacious hammer in the wet returns. Hope I get a chance to comb over the system.
