I want to add a Wi-Fi thermostat but do not have enough wires.
clydesdale
Member Posts: 84
in Oil Heating
I have hydronic air handlers are heated by a fuel oil boiler. I have Central AC using those same air handlers. I wanted to use a Wi-Fi thermostat but I do not have any leftover wires in the wall. My understanding is that I need one more wire to power the thermostat. What are my options? Thank you
Redlink is so good I'm using it and I have 8 wires run to my stat. The Prestige only needs two but is probably the best tstat out there.
- 120 Geothermal
