Replace one radiator (TRV) with in-floor loop, which parts needed?
alesage
Member Posts: 5
In the middle of a renovation I've discovered one of my radiators is unusable, would like to experiment with an in-floor loop for this room.
I have a Weil-McLain Aquabalance combi boiler, 6-zone system, with TRVs for each radiator, and I'm using a Taco infinitely variable pump--it's very much like this Siegenthaler system.
I believe that I can simply run the loop in place of the radiator with a few extra parts, and I'm hoping to be corrected
A few questions:
I know that I'll need a three-way mixing valve to adjust the temperature, and I think the pump should supply the head I'll need. I think I still want a TRV? If I leave the loop open, e.g. just with the mixing valve, that loop will always be calling for heat. So the TRV, then a three-way mixing valve?
Secondly is the TRV just sticking up out of the floor? What kinds of controls do we use that can be embedded in walls or floors? I like the primitive no-electronics, no-fuss TRV style and I have wall dials for all the other radiators.
Thanks all, these forums have been very helpful in getting up and running.
A few questions:
I'm no expert, but I have seen a lot of options for remote sensors for TRVs the oventrop catalog. They have two options that might work, one with the sensor built into the wall dial and one with a separate sensor and wall dial.
https://static1.squarespace.com/static/5706554c356fb026ac07a044/t/59f0ab2590bccec2417a2771/1508944692507/OV_Thermostat_Guide-170914.pdf
No TRV, better off picking a brand of radiant tubing and use their sizing software to properly size the system and lay out the loop/pattern.0
- 167 Indoor-Air Quality
