Bosch GC124-25 sensor error lockout?
lrodptl
Member Posts: 10
Both my heating zones are cold and this message is on Boiler panel-Sensor Error Lockout. Can I reset it?
Sure give it a try, if it works great but call a tech to have a check up. It's trying to tell you it needs help.
D0 -
Wouldn't reset,I'm in Boston and it's Superbowl Sunday and the Patriots are playing and no one will come, 2 walked me through some TS but no answers yet. Maybe a damper switch?
Grab the owners manual, go to maintenance and do what you are comfortable doing. Many many times cleaning drains and such can get you by. Usually your annual check up will cover these easy fixes.
D0 -
Aquasmart?To learn more about this professional, click here to visit their ad in Find A Contractor.0
Yes,Aquasmart. Wouldn't reset no matter how long I pressed reset. Heating guy was supposed to call back and tell me what pins to jump on the damper switch but the Superbowl must have gotten in the way.
Changed the 2N1 sensor (2 minutes) and all is good.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
