Bosch GC124-25 sensor error lockout?
lrodptl
lrodptl Member Posts: 10
edited February 2019 in Gas Heating
Both my heating zones are cold and this message is on Boiler panel-Sensor Error Lockout. Can I reset it?
  • DZoro
    DZoro Member Posts: 1,048
    Sure give it a try, if it works great but call a tech to have a check up. It's trying to tell you it needs help.
    D
  • lrodptl
    Wouldn't reset,I'm in Boston and it's Superbowl Sunday and the Patriots are playing and no one will come, 2 walked me through some TS but no answers yet. Maybe a damper switch?
  • DZoro
    Grab the owners manual, go to maintenance and do what you are comfortable doing. Many many times cleaning drains and such can get you by. Usually your annual check up will cover these easy fixes.
    D
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,593
    Aquasmart?
  • lrodptl
    Yes,Aquasmart. Wouldn't reset no matter how long I pressed reset. Heating guy was supposed to call back and tell me what pins to jump on the damper switch but the Superbowl must have gotten in the way.
  • lrodptl
    Changed the 2N1 sensor (2 minutes) and all is good.
