Hydrosketch, export as image?
Is there any way to export a Hydrosketch drawing as an image? I read through the manual and searched for an option to do it but found none. I did a drawing that I wanted to post but I can't think of any other way to do it other than taking a screenshot.
Never stop learning.
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    I don't have it. Yet. So, I can't answer that.
    Is it as easy as advertised?
    Steve Minnich
  • Leonard
    Leonard Member Posts: 903
    edited February 2019
    For other stuff I hit "print screen" button on keyboard, to copy it to clipboard, then MS publisher (office) to clip off the junk I don't want.
  • Mike_Sheppard
    Mike_Sheppard Member Posts: 698
    @Leonard thank you. I will do that.
  • ratio
    ratio Member Posts: 4,176
    There's also the snipping tool, stock with Windows since IIRC XP or so.
    hot_rod Member Posts: 26,625
    if you have a Mac, Option/ shift/ 4 gives you a crosshair, trace the sketch and it appears on your desktop.
    On my laptop I have Snip it works the same way.
