Genisys Primary Control, broken reset button
STEVEusaPA
Member Posts: 6,505
I've come across this 3 times this year with new customers so I don't know the history of use (abuse?).
Seems like the reset button won't work on this primary. Won't press down, won't stop the burner, and of course, won't reset or let you into pump prime mode.
I took the latest one back to the shop, took it apart. Seems like you can work it back free again from the inside of the cover, so I'll throw it on the shelf as an emergency back up. I guess there is a tiny spring or something in there, just didn't want to destroy it to find it.
Anyone else come across this?
Just wondering.
Steve (freaking cold today)
Just wondering.
Did it have a plastic film over the top of controlTo learn more about this professional, click here to visit their ad in Find A Contractor.1
I would contact Beckett, it's their product.0
No plastic film, just the label with a clear film part over the button. But your comment had me take a razor knife and cut away the part over the button and it appears to work fine.Robert O'Brien said:Did it have a plastic film over the top of control
Not an answer to your delema but would a burner with that defect still lock out on safety??0
Didn’t test it, just replaced it. But I don’t think it would affect it.
Seems to me the plastic that’s part of the label and over the button bonds to the button and wouldn’t let the button depress.
So carefully cutting that away seemed to be the fix.
I wonder if heat is the culprit-either from the burner or from the control itself.There was an error rendering this rich post.
That's funny. Never had that problem with the Genisys. I did get frustrated and pressed harder on the button. I figured they went from a button to a touch pad. Whoops. Now I know.
Thanks0 -
The heavier clear plastic covering can make the button very difficult to push. It's to help with water resistance. It's been redesignedTo learn more about this professional, click here to visit their ad in Find A Contractor.2
is there a technical bulletin on it?Robert O'Brien said:The heavier clear plastic covering can make the button very difficult to push. It's to help with water resistance. It's been redesigned
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
