Baxi Luna 380 HT E110 Error Code
dbz
Member Posts: 2
I am looking for a Baxi technician who has installed these units and can troubleshoot them. Your recommendation will be appreciated. The Baxi units are in an apartment building near Hartford Connecticut.
That is a high limit switch code check to make sure you have no air in system. Also make sure pump is pumping flowing.0
Thank you.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
