Baxi Luna 380 HT E110 Error Code
dbz
Member Posts: 2
I am looking for a Baxi technician who has installed these units and can troubleshoot them. Your recommendation will be appreciated. The Baxi units are in an apartment building near Hartford Connecticut.
That is a high limit switch code check to make sure you have no air in system. Also make sure pump is pumping flowing.0
Thank you.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
