Crown Boiler Control setup
NYCHomeOwner
NYCHomeOwner Member Posts: 13
edited January 2019 in Thermostats and Controls
Does anyone know someone that could possibly help me wire up my crown steam.
. I set Everything up just need to connect my vxt24 water feeder, thermostat, relay , water cutoff system. I'm located in Queens Ny. Would be great help.
  • JohnNY
    JohnNY Member Posts: 3,358
    What's the back story here? Why isn't this pre-wired from the factory? Is this a second-hand boiler?
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • STEVEusaPA
    You HAVE TO get a pro in there. After it's wired up, the combustion & draft need to be set up with an analyzer, gas pressure confirmed with a manometer, and safety controls tested.
    You saved all the money you can doing most of it yourself.
    NYCHomeOwner
  • NYCHomeOwner
    edited January 2019
    It was new but i had someone come in that supposedly was going to do all the work, plumbing etc and he took all the wiring apart. I pretty much seen and didn't like how he didn't go by code on certain things, so i paid him for his time and asked him to leave. That's where i started this whole project by my self. I really just want a pro to come in and set this baby up at this point the correct way as you mentioned with an analyzer to confirm correct numbers.
  • STEVEusaPA
    There are some great ones in NYC
    https://heatinghelp.com/find-a-contractor/
    Keep in mind not many contractors like to come in at this point and assume all the liability of finishing up a job, because we've all been hit with "Once you touch it you own it".
    Post some more pictures back a little farther if you can.
  • NYCHomeOwner
    edited January 2019
    I had a member from the forum help me out. Thank you guys
