Crown Boiler Control setup
NYCHomeOwner
Member Posts: 13
Does anyone know someone that could possibly help me wire up my crown steam.
. I set Everything up just need to connect my vxt24 water feeder, thermostat, relay , water cutoff system. I'm located in Queens Ny. Would be great help.
What's the back story here? Why isn't this pre-wired from the factory? Is this a second-hand boiler?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
It was new but i had someone come in that supposedly was going to do all the work, plumbing etc and he took all the wiring apart. I pretty much seen and didn't like how he didn't go by code on certain things, so i paid him for his time and asked him to leave. That's where i started this whole project by my self. I really just want a pro to come in and set this baby up at this point the correct way as you mentioned with an analyzer to confirm correct numbers.0
There are some great ones in NYC
https://heatinghelp.com/find-a-contractor/
Keep in mind not many contractors like to come in at this point and assume all the liability of finishing up a job, because we've all been hit with "Once you touch it you own it".
Post some more pictures back a little farther if you can.There was an error rendering this rich post.
I had a member from the forum help me out. Thank you guys0
- 120 Geothermal
