Doyle 2A vacuum valve
Doester
Doester Member Posts: 17
Is there any difference between a “vacuum valve” and a regular air vent? I was going to replace this with a Hoffman 1A so I could slow it down. Single pipe steam system.
Thanks!!!
  • Danny Scully
    Danny Scully Member Posts: 1,462
    There is a difference @Doester. Vacuum vents had check valves that enabled the system to go into vacuum after the air had been vented. I say HAD because they don’t make vacuum vents for radiators anymore. So, the Hoffman 1a would be fine.
    Doester
  • Doester
    Thank you!!!
    Steamhead Member Posts: 17,949
    Do the rest of your radiators have vacuum vents? How about the vents at the ends of the steam mains?
    Consulting
  • Doester
    No, only 2 vacuum vents out of 16 radiators. And the main vents were “Hoffman float quick air vents”. I’ve replaced them with bigmouths. Thanks!
