Dole A1 Valve
ksd99
Member Posts: 77
I am replacing some valves and 9 notice that some of the old ones and some new ones don’t have the rubber/plastic tube sticking out of it. I’d this an issue? See pics.
New owner of 1 Pipe Steam Boiler - learning all I can- no real steam pro in S.W. Michigan - if you know of 1 -let me know.
That's just a drip tube to let condensate drip back into the radiator. It should not be an issue. Probably wasn't needed in the beginning.0
Thanks Fred.New owner of 1 Pipe Steam Boiler - learning all I can- no real steam pro in S.W. Michigan - if you know of 1 -let me know.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
