Furnace won't light off
happysenior
Member Posts: 3
in Gas Heating
My S8610U module will not give my gas valve 24vac to.open the gas to the burners ? Pilot on.
Need some more information. Pictures would help.
D0 -
its on a coleman mobilehome furnance #7600 that has a new honeywell pilot retrofit kit Y8610U....Just installed a new module,as one I got with kit failed. It worked good for a week and just quit.😪it works for a few days,then quits.😿
Furnace is over 30 Yrs old.! Should I take burner out and clean good ? Just put in new blower motor.pilot light works good...0 -
Very possible you may have 1: bad heat exchanger or 2: Rusted chimney vent and intake piping.
Does it light the burner and then a few seconds later flame goes out?
D0
