Which conversion kit for WM EG-55
Joy10
Member Posts: 2
We have an old Weil Mclain EG-55 PI Series 1 water boiler. To replace the gas valve, Weil Mclain says to use the conversion kit 510-811-459. However, the gas connection pipes are 1/2", and the old gas valve is 1/2" as well.
This kit has a 3/4" gas valve. Would it be fine to use it with fittings?
Shouldn't the correct kit model should be 510-811-458, which has a 1/2" x 1/2" gas valve?
The kit probably comes with a thread reducer to reduce down to 1/2”.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Yes, flush reducing bushings.....does everyone save them like I have? Always extras.0
Thank you so much, that was very helpful.0
- 50 Industry Classes
