Oregon Public School Boiler Room Mystery
jamesfranks
Member Posts: 1
Would anyone know what this is? Found in boiler room of a school we are renovating.
Thanks,
Is the bottom arrow fixed solid or does it spin?0
Looks like some kind of manual auger0
Acme thread on that... I wonder what that fitting on the bottom might have matched with? I'll bet the thingy (anyone have a better word) in the middle there fit into some kind of socket -- possibly a socket with a clamp which bolted over it -- and it was used to adjust the opening of something, like a window... or a damper...Br. Jamie, osb
That thread reminds me of post jacks used in a basement for sagging beams. The pitch of thread looks like it could apply a lot of push or pull to something.
Was there a coal burner in there?
Maybe something for the CI grates?0 -
Depending on what the attachment on the lower end is made of, it reminds me of a valve seat dresser like my grandfather used in his shop in the mid 1960's. I repaired many valve seats then with a tool that looks just like this one.0
Punch a fire tube on a boiler ???0
Tool of torture?
They had different ways of dealing with naughty boys back in the day.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
A step above the rap on the knuckles with a ruler?
It looks like something to deal with boiler tube problems to me.—NBC0 -
Whatever it is it is very well constructed so it did not come from the Harbor Freight catalog0
I'm thinking a puller of some kind - the threaded crossbar would sit in a groove on the outside, and the end piece would lock into whatever was being pulled.0
interesting. what are the dimensions?Miss Hall's School service mechanic, greenhouse manager,teacher and dog walker0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
