Taco 219 swetchek problem and possible internals swap
286merc
Member Posts: 2
The one installed about 25 years ago appears stuck open allowing gravity flow. The Taco circulator is OK
Can this be adjusted up and down to possibly free up?
If not can I swap internals with a new one and save the hassle of soldering in a very tight spot?
You can back it out and try to "bounce" it. Circ on and off. Then tighten it back.
Or get a new one and just replace the insert.0 -
Hi 286merc
the 219 check valve replacement valve seat assembly part number is 219-230RP. Did anything in the system change; Pump perhaps? 219 check is a weighted check, and usually lasts forever. You might have system debris in the check valve hindering seat assembly from stopping flow. if that is the case, isolate the valve, remove the top portion of the valve seat assembly which is all one piece, and clean out the cavity of system debris. Reassemble and it should be fine. of course this provides an opportunity to inspect the seat assembly for corrosion or damage too. For additional questions troubleshooting the problem, please give Taco tech support a call at 401-261-4890. please let me know what the issue was. thanksJoe Mattiello
Taco Comfort Solutions2 -
Thanks for all that Joe. We recently had the well pump replaced and I flushed the 100 gallon holding tank several times to remove sediment plus replaced the whole house filter. I guess I missed something such as flushing the boiler also.
I'll follow up your suggestions in a few days after this blizzard passes.
On a side note is there any GOOD/SAFE additive to clean the boiler? It is a 12 year old Hydrotherm 3 section PB-105W. The water here in NH is semi hard.0 -
A kit like this from Rhomar is a good option, a cleaner, flush, refill and add conditioner.
Semi hard water? Nothing over 7-10 gpg for boilers, even with a conditioner.Bob "hot rod" Rohr
Living the hydronic dream0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
